Displays real-time CPU utilization information by process.
N/A.
Use this command to show the percentage of CPU processing devoted to each process, sampled every 5 seconds.
| Key | Action |
P |
Sort process list by CPU utilization |
T |
Sort process list by time usage |
N |
Sort process list by number (process ID) |
M |
Sort process list by memory usage |
q [Ctrl] + c |
Exit the top program |
For more detailed information about the top command including display options, command fields, and command usage, please refer to your UNIX documentation.
The following command displays the real-time CPU utilization information by process:
top
This command was first available in ExtremeXOS 11.0.
